OMC Cobra Tilt Trim Hose replacement
lewisj
I have a 1994 Chris Craft with an OMC 5.0 HO Ford engine Mod:502APRJVB Ser: T01262907 and Cobra Outdrive Mod:987246 Ser:T000776031. <br />One of the trim hoses from the pump to the ram needs to be replaced. While I can see where the hose terminates at the manifold from the engine compartment there is no clear access to the nut. Is there a point of access from outside through the transom?
Re: OMC Cobra Tilt Trim Hose replacement
I've Never even Looked at a drive like Yours......<br />But,<br />On a Merc., You can see the trim hose manifold at the very bottom of the transom housing...........<br />Under the Boat.....<br />Couple of nuts,+ you'll need some silicone to seal it back up........
