Re: omc cobra, running hot
Thanks for the replies. I have changed the thermostat,But I belive the problem is with the water delivery. I have replaced the impeller,and liner.I made sure the liner was centered in the houseing. If I run this with the muffs on, I can see it drawing water from the muffs for a few seconds, then the water will blow out around the muffs for a few seconds, then it starts to draw it in again. this coinsides with the water exiting through the exaust. I test the flow at the hose right at the transom at the inside, I get a good upward streem of water, then the water actually goes back down through the hose, then a good streem again, and so on. I read about seal leaking around the tube from the pickup in the lower unit, and drawing in exaust, has anyone ever actually seen this? or am I way off base with this thing? Thanks to all who take the time to help with this stuff.
