Hi, I'm in the process of de-winterizing my boat and wanted to fully lube the sterndrive. With my Clymers manual, I was able to change the gear oil, lube the splines and u-joints, but I can't find the specific grease for the gimbal bearing(zirc fittings on the starboard side). My manual calls for OMC Wheel Bearing Grease, but all I can find at West Marine and some other places around here is Pennzoil Marine Multi-Purpose Grease. It says it works on trailer wheel bearings, but will it work for a gimbal bearing? Also, how many pumps of the grease gun do you put into the gimbal bearing? Did I miss any lubing spots? Anything else before I put her in the water? Thanks!
