Re: OMC Cobra 5.8 sterndrive removal
To remove, undo the two nuts at the aft end of the trim rams, remove the shaft, remove the 6 5/8ths nuts, pull off the outdrive. You can also take off the top cap on the outdrive and see if the oil level is correct and if their is any damage to the upper gears on the outdrive and contributing to the "lock-up".
