Chris Martin
- Jun 17, 2012
- 4
Hey guys hope you can help. I have a 1991 VIP Kona with a 5.0 OMC Cobra. I was running it this weekend and all was well. I was running around 55-60 mph, at about 4500 rpm. When I got out of the throttle, I heard a gnawing sound coming from the out-drive. I shifted into neutral, and the sound continued. I killed the engine and pulled it to shore. With the boat trailer-ed and in gear when you turn the prop you could feel it slip over the gears. I have since pulled the out-drive, and separated the upper and lower unit. It had plenty of fluid in the unit. There were some small metal flakes found in the fluid. The upper gears and bearings appear to be fine. I am thinking that the lower unit gears have come apart. Is there anyway to inspect the lower gear unit? I have had the boat about 3 years now and it has never gone in to reverse, could this be part of the problem? I understand engines, but the out-drive is all Greek to me. Any help will be greatly appreciated. I have never seen a boat like this one, and really don't want to scrap it and start over, but I don't want to spend more than it is worth to repair it.
