I put a new impeller in as a precaution with the boat sitting for a year, and I had gotten sand in the cooling system. Started it up, was circulating water fine, idled to bring temp up, and it kept going up - shut off before got too hot. Impeller housing got very hot, so I knew what likely happened. The impeller just disentegrated - not melted.
This is the second time its happened, with the same brand impeller I bought at the same time. I used another with no problem in between. I noticed that the ones that came apart had a harder feel than the one that did not.
Anyone experience impellers doing this?
Now I need to take the hoses off and back flush everything - anything else to do?
