I've just become the proud owner of a boat with an OMC Cobra 3.0 Litre (1987)with a stern drive. At low speed everything is fine, but revving up to 1800 rpm and above gives an overheating situation which I have tried to locate the cause of without success.<br />I have:<br />- Put in a new impeller + gasket<br />- Checked the rubber tubes<br />- Taken the manifold end and 'knee' off, changed gaskets & checked for free flow and leaks between the exhaust flow & water ducts, cleared the ducts from rust flakes & debris.<br />- Removed the thermostat (out of stock at the dealers) <br />- Checked that water is coming into & out of the system.<br />- Tightened the drive belts to optimal position<br />- Checked for water in oil - none<br />- Put in new spark plugs ( old ones were incorrect type)<br />I live in Sweden and my boat is in the Stockholm archipelago. Water temp around 20 degrees C. We are having great summer weather, and I am longing to make a trip with my family in our 'new' boat.<br />Any tips?<br /><br />------------------
