jeffmorris
- May 17, 2010
- 6
Is an alignment tool necessary? I'm replacing the gimbal bearing and u-joint bearings along with the bellows. Ive seen posts suggesting the use of an alignment tool or even using the actual shaft as an alignment tool prior to reinstalling the lower unit.
If the coupler is out of alignment from pulling the shaft out wouldn't it be out of alignment after you remove the alignment tool? Is the alignment tool more than a tapered shaft?
I'm familiar with a automotive clutch alignment tool but fail to get how this works.
Any explanation would be helpful.
