lakelover
- Mar 26, 2003
- 4,386
My 9.9 came with a 3.5 gallon gas tank. I wanted a larger tank & had an OMC 6 gallon metal tank with a relatively new hose, so I bought a mercury fitting for the motor end and hooked it up.
I took it for a short run and it seemed to be OK, so I docked it. When I came back later, gas was dripping out of the motor through the carb until I unhooked the gas line. I had been told this setup should work, but it seems there was too much pressure in the tank or something. Switched back to the 3.5 gal. tank and it has been fine since.
Was it because the Merc tank is vented and the OMC is not?
Thanks.
Thanks.
