The cylinder block and crankcase part numbers are different for the 6 and 8 (.ie, 1994 model year, 6hp Cyl. & CC is #433929, 8hp is 433930.) Carbs get different part numbers, too. They share the same head and pistons, so the compression is the same...
More than likely, the porting is different on the blocks...
I had a closer look at the porting on the 6 hp. the porting is quite porty with big
holes, I can?t understan how it could be changed to 8 hp by modifying them considering that the ports are so high as they can be drilled on an serial production engine.
What if the case is planned? Where can I get reliable compresson figures for both?
