Puzzling new symptom from my 5.7 1993 OMC. After about 4-5 minutes at W.O.T. I slow to an Idle and hear a distinct valve tapping and dead miss. This will drift away over a minute or two and miss will too. I only have experience with lifter being flat at idle when first started Any body seen this before? It's not spitting through the carb so I geuss it's prob an exhaust valve sounds like its on the port side all the way back to the back cyl near the transom. Do you think the valve is sticking,or the lifter is failing at high speeds?
