I have a 1988 Nordic Crestline Rampage 21' with an OMC 5.7 Ltr Cobra. I have replaced Engine Thermostat, Raw water/Outdrive Water pump housing and Impeller with cage. Problem is at IDLE with ear muffs on water flow is 0 output at the Engine thermostat incoming hose. Becuase of this, The engine Heats up at IDLE only. When you rev the motor up, Water starts to pump. I have resealed and reseated the Raw water/outdrive pump twice plus checked for Clogs from lower screens to pump, and then from pump to Engine thermostat housing. Im wondering has anyone seen the Pipes that run inside the outdrive rot out ? or get pourus ? Has anyone run into this problem themselves ? Again, at High speed she spits water fine, Just at idle is the problem. For now I am using the boat, when its in the Ocean and above and idle it runs ever so slightly on the hot side ( bout 175 , Normally ran 160 ) Any help or advice appreciated.
