Hi, need some help with a bogging issue. 1988 Omc 5.0 Cobra, just purchased at the start of the season. Ran pretty good for the most part, but in the glove box was an uninstalled Pertronix Igition kit, so I figured I'd throw it in, along w/ a new cap and rotor. Starts and idles ok, but when you give er some gas it bogs. Will stumble along till on plane and then does ok. Not spectacular but just ok. RPM's wont go much over 3000 WOT. I've put the points back in and it runs fine. Done this a couple times while experimenting with timing (and idle adjustment as it initially had a hard time running at all)and i like the starting and idling of the pertronix over the points, but just need to work the acceleration problem out. I saw a previous post that talked about changing the timing advance mechanism when doing the conversion, but it didn't go into detail, and the kit didn't have any of that in it. Any thoughts will be greatly appreciated.
