weiser boat
- Jul 17, 2014
- 3
My 1996 four winns with 5.0 cobra has been in the shop for 2 weeks but the mechanic can't locate the problem. I was pullling a skier and it was running great. The skier fell so I turned around to pick him up without turning the engine off. When I tried to accelerate to pull him up again it would rev up and back off every few seconds and continued doing that as long as I pushed the throttle. If I try to go any faster than an idle it revs up and backs off. It doesn't die or backfire. It starts and idles perfectly. My initial thought was fuel or carb. The mechanic focused on electrical issues stating it has electronic fuel injection and has done the following:
1. immediately discovered the altenator belt was broke in half, replaced it but same issue
2. noticed the voltage would drop when push the throttle
2. thought the "computer" needed to be reset because I pull the battery in the winter which shuts it down. To reset it he would let it run for a couple of hours,still same issue
3. sent the altenator to be rebuilt. It needed new bearings. Still same issue
4. has run all electrical tests and all results are fine
5. changed fuel filter
6. checked presure out of fuel pumps, that's fine
7. did note the fuel tank had some "junk" in it.
I checked with two other dealers and they tell me this guy is the best in our area and has a reputable business. Has anyone had this issue and if so what was the problem?
Thanks in advance for your help
