OMC 400 water pump question
badams270
I have a 1981 seaswirl with a 120/400 outdrive. Whats happeneing is I have ran it on ear muffs with no water coming out the pee hole. I put it in a barrel and ran it again. no water out of the pee hole. But, it is pumping water. There is a hole that has quite alot of pressure up on top of the drive that appears to be for the ball gears. Why would there be no water out of the pee hole if its got good pressure up there?
