Re: OMC 4.3L Problem
I know this is an old post, but I need help with a problem VERY similar to what's described above.<br /><br />The boat runs wonderfully - starts fine, runs great at cruising speed, and responds perfectly once the rpm's are above 2K or so.<br /><br />The problem is off-idle - for example - when pulling up a skier. After tightening the rope, when I nail the throttle the engine hesitates for a fraction of a second, and a few times has altogether died. Easing into the throttle is not a problem.<br /><br />I've done 2 things - re-gapped the spark plugs from about .036 to .030, and replace the fuel filter. The problem is better, but not solved. It doesn't die anymore, but there is still an instantaneous hesitation off-idle.<br /><br />According to DHD's suggestion it sounds like the points may be a problem. Especially since I DO have an occasional engine stumble when I adjust the trim. <br /><br />What I really need to know is...what are "points"?
