OMC 4.3L Problem
kimbro12345
I have a 1989 OMC with a 4.3L v-6. I'm having trouble with the boat dying when I put it into gear. It will idle fine sometimes, but when it is put into gear it dies. Had to float back this last time, can anyone help?
Capt DHD
Re: OMC 4.3L Problem
Hello;<br />When was your boat last serviced by a dealer? Also, will the boat cut out, when it is idling, if you trim the unit?<br />1)You have a point ignition, when put under a load, questionable points will break down. Questionable points will also break up when you hit your trim switch.<br />2)You may have a problem with your outdrive that should be checked by a certified dealer. <br />For you I hope it is #1, #2 could get a little more expensive.<br />Good Luck, Rob.
Odin
I have been experiencing the same thing. I noticed that the problem was more frequent, when I ran w/ a 19 prop. <br />The problem was that the idle was too low, so I adjusted the idle speed on the carb. That seem to take care of the stalling when I would put it in drive.
