I purchased a 1988 20ft Four Winns with a 4.3L OMC engine in Dec. 04. The Marina winterized and summerized ( new spark plugs) the boat before I put it in the water. The engine had a 1/2 tank of gas and I filled it up the tank before I put it in the water. The engine will start but only at full throttle and after 20-30 seconds of cranking (I've since put in a new battery). The engine will not idle and it runs very rough. Once underway it has limited power even at 3500 rpms. I changed the Fuel/Water seperator filter and I have added a 4 ounces of Fuel Stabilizer because I thought there might have been water in the fuel.<br /><br />Thanks in advance for the help!
