dodgezilla04
- Jun 3, 2009
- 21
I might be missing something simple here.
1987 18' Searay cuddy. has a 175hp OMC 4.3 Chevy V6, 2 BBL.
Boat was not maintained well, and sat for 4 years. so i started out with everything since it wasnt running.
Had the Carb rebuilt and calibrated by a shop in Seattle
new cap, rotor, plug wires, plugs, condensor, points, filters... set the dwell at 39*, timing at 10*btdc.. compression is 155-165psi. firing order is correct.
warmed it up, changed oil and lube filter. adjusted the shift cable, it was idling on 3 cylinders, now is fine.
drained the fuel tank completely. checked the vent for obstructions, none there.
starts quick, idles really smooth, runs well. here's the problem. it has no power.
not in gear it will instantly rev up to full speed, no hesitation.
underway however, its really slow to get up to Rpm(and plane out) and only reaches 3400rpm. moving the throttle to full just doesnt do anything, it will not gain rpm. Top speed is 29mph, this boat used to make 37mph several years ago. The prop is the same that has always been on there and is not damaged.
the fuel pump appears to be keeping the bowl full, i am going to install an inline pressure gauge between the pump and carb, hoping to see around 6psi.
what am i missing????
this being a 22 year old boat, is it possible that the foam is waterlogged and she's just too heavy?
what should this boat weigh? i can go weigh it and the trailer, then just the trailer to check its current weight....
i'm missing something here. help please?
