<br />Greetings - I am trying to remove the lower unit with the upper in place. The SELOC manual says to just lower the housing down and away until the shift rod disengages. I have been pulling hard on it to get it to release with no success. Is there anything else to it to get the shift rod to disengage? I don't want to force it and damage something else. Also, the manual calls for rotating the shift rod head to engage the pin when reinstalling - it sounds like they are assuming the upper is removed as well. <br /><br />I had a new impeller completely disentegrate, and am getting no water flow with a new one, so I am taking it apart to clean it out and put new seals on the water tube.
