Re: OMC 4.3 Cobra sterndrive weight??
Robar<br />I pulled mine myself.Mine is a 1991 4.3 cobra.<br />The way I found to do it,at least this worked for me.I set a small piece,couple feet square of plywood under skegg.I lowered the drive tilt down till skegg made contact with plywoof.I raised or lower my bow jack to get the drive as vertical as I could.I undid the rams at drive end,don't let them just fall down so you don't damage the hydr. lines,tie or wire them.I undid the 6 nuts,3 each side,then I grabed hold of the big bolt that the rams attached to and rocked drive back and forth.If you must pry on it to get it loose be carefull not to damage surface.Once you get it to start coming out,rock it back,be sure to support the drive shaft as it comes out of bellows. Once I cleared the bellows with drive shaft I just picked it up by myself and carried to wooden stand I had made to set it up right on.I had to problem picking it up.Felt like it was about 100 pounds.Now I am not considered to be a hoss so take it for what is worth.
