Lou C
- Nov 10, 2002
- 13,122
Finally got the boat in the water, and I noticed that it tends to idle somewhat roughly and lacks power--seems to miss when a load is put on it. I changed the spark plugs, and checked the dwell, ignition coil, and timing. The coil's secondary resistance is too high by about 2000 ohms, so I am going to put in a new one. Dwell was OK, as was the timing, and the spark appears to be advancing properly. I am going to replace the cap, rotor and wires as well. Any other ideas before looking at the fuel system (Rochester 4bbl). Compression was checked recently and was 180-190 in all 6 cyls. No water in oil, no overheating. Carb accel pump gives a good squirt in each primay barrel.<br />This is a non balance shaft V-6, do they generally run a little rough at idle and low speeds even when everything is in good shape??
