Re: OMC 3 Litre GM Breaks down under load, Backfires thru carb
Check for compression and good spark on all cylinders first first.You'll have point ignition on that engine unless it's been upgraded so point gap effects timing.If the points are at all suspect replace them (condencer as well )there cheap. If compression is good and you have good spark the last thing is fuel.Has the boat sat all winter ? did this start happening gradually or all of a sudden? Let us know.
