OMC 3.0 Timing Mark
MichaelSch
Hi,<br />i have an OMC 3.0 Motor in an ebbtide montego and i want to adjust the ignition with a flash, but the sheet metal that normally shows the TDC is so rusty that the timing mark or marks can not be seen any more. I have an omc repair manual but the sheet metal is not shown in that detail that i could restore the position. An image of the sheet metal with the marks on it would be very helpful and i would be very happy if somebody has it or could make it.<br />regards<br /><br />Michael
Mod2
Re: OMC 3.0 Timing Mark
Welcome to iboats Michael! You've posted your question in the wrong forum so I'll move it over to the I/O forum for you. You should get an answer to your question there.<br /><br />Good Luck!
