ArnoldKraan
- Oct 15, 2004
- 12
this is a quistion about an OMC 3.0 sterndrive from 1988 mounted in a bayliner capri<br />Under normal circumstances the boat run's fine, but when it has been running at WOT for a few minutes it stalls and starts running idle.<br />Yesterday I could not start it up after running at WOT.<br />I removed the metal hood from the fuel filter to check if there was fuel, after doing only that it started up at once (even without the metal hood).<br />reinstalled the hood and we cood run slow to the harbour, even 3000 Rpm was Ok<br /><br />There is no water/fuel separation filter in between.<br />Could it be that there is a vacuum in the fuel tank when I am using a lot of fuel, the tank was less the half full.<br /><br />Arnold<br />Neherlands
