I have plenty of spark, gas flow, and compression. I replaced the ignition switch and did several small things. I've heard that the problem is probably the shifter plate and/or the switches on it. I was looking for some sort of diagram on how they are supposed to be positioned and so forth. I heard they have to be lined up perfect to let the boat start or this problem happens. any insight, a copy of the diagram and how to position them properly would be appreciated. thank you
