OMC 120hp electric shift wiring???
jlam
I have a 120hp OMC out drive with electric shift and am swapping the shift control with the outdrive to another boat. My question is where do I hook it up to the ignition? I know the controller is good I tested it threw the wiring harness with a hot wire and test light. So I?m guessing to the accessory? There is just two wires a purple one that controls the forward and reverse and the white one is for the neutral.
Redrig
Master Chief Petty Officer
Re: OMC 120hp electric shift wiring???
connect purple wire to the "Run" terminal on ignition switch
I cant remember off the top of my head where that white wire goes, it basically will not allow you to crank the engine if shifter is not in neutral.
