All new tune up new carb won't run after 1/4 throttle help
B bfriction55@gmail.com Recruit Joined Sep 27, 2020 Messages 3 Sep 28, 2020 #1 All new tune up new carb won't run after 1/4 throttle help
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 51,875 Sep 28, 2020 #2 first, welcome aboard second, be very specific. what did you do for a tune up? for the points, what was your dwell? what did you set timing to?
B bfriction55@gmail.com Recruit Joined Sep 27, 2020 Messages 3 Sep 28, 2020 #3 Everything is new timing is right could there be a problem in the intake exhaust?
southkogs Moderator Staff member Joined Jul 7, 2010 Messages 15,085 Sep 28, 2020 #4 It was running correctly before the tune up? And it's idling smooth now?
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 51,875 Sep 29, 2020 #6 what did your dwell come out to after filing the points and re-gapping to 0.018" should be about 30-32 degrees if you didnt verify the dwell, it will idle great and fall on its face as you open the throttle.
