Rockpainter
- May 28, 2006
- 9
Have older (70's)Sears kicker on my boat.<br />Will start after I shoot starting fluid into chamber thru plug hole.<br />After that it will start right up but if I let it sit for a couple hours,I have to do the same thing.<br />It runs and idle down fine, the air mixture valve is working fine.<br />How does the engine get gas to the chamber initially? could a line be blocked?.<br />It also will struggle at top end.
