Apparently I don't have one. My outdrive kicks up in reverse and slowing from the plane. I just bought this boat 68 bellbouy I ran the serial # on the outdrive and it shows up as a '70. I came here and did searches and researched this valve, downloaded the manual.I figured it was a simple matter of rebuilding the valve or finding a new one ( pricy) As far as I can tell I dont have one installed. Its not attached to any of the shifting linkage, the lines leading from the pump just go out to the trim cylinders, both attaching into the bottom of the pump. My question is, is there a model that has the reverse lock valve is built into the system somewhere? pump, cylinders?
If it was in fact repowered. and not just a registration goof up on the year of the boat.. and they simply left the valve off is there a way to fix this problem. It really doesnt look like a repower, or else they did a very clean job. Many thanks in advance, and I love this site I have lurked here gleaning lots of information from your forums and articles
edit to say its a 165
ok Im pretty sure now it has been repowered, as the registration is a 120 hp., I didnt notice before..
On the bottom of the pump the left smaller line goes out directly to the cylinders. the one on the right goes down and looks like it goes through into the sterndrive I saw no valves attached to the shift linkage at all .. also it appears the line on the bottom of the pump is crossed threaded unless it goes in on an angle like that. couldnt get my head low enough to pick up what the camera did
