Hello, first post here. Brand new to boats and not really mechanically minded. I have searched this forum and the internet regarding this problem, but can't seem to find a similar situation.
Backstory...traded my ATV for a little fishing boat, trailer, and motor. I believe that the motor is a mid 90's BF100 but not exactly sure. It has a white cover with a yellow, light blue, and dark blue stripe. Serial number is B100S - 1708263 I believe. Anyway, the fellow I traded with seemed like a pretty straight shooter and claimed to have used the motor recently with no problems. I took his word for it without seeing the motor run...my bad. Got the motor home and got it in a bucket and surprise, surprise it wouldn't fire up, or if it did I died after 10 seconds. I pulled the carb and cleaned it, cleaned the tiny fuel filter, cleaned the gas tank and got new gas, re-cleaned carb and now it runs pretty good from what I can tell.
Next I emptied the gear oil from leg...it looks like some water is getting in somewhere so thats a project for another day.
Finally drained the motor oil...it looked not too bad overall. Filled up the oil and fired her up again. Good steady idle, steady stream of water coming out of the little hole, green oil light on and bright. Now for the problem...when I give it throttle the oil pressure light starts to flicker and eventually, as the RPMs increase, it goes out completely. Everything sounds good, but obviously there is a problem somewhere. Since the motor is probably only worth $500 I dont really want to dump much money into it at a shop so I am trying to diagnose and hopefully fix the problem myself. From what I have read, my first thought is that the oil pickup tube could be plugged which would require pulling the powerhead to clean it. As mentioned, I am not real mechanical but maybe with a repair manual I could figure it out. Any other ideas of what it could be?
Thanks in advance for your help.
Jon
Jon
