older evinrude
fishi
I have a older evinrude outboard that I don't know the HP or year. I only know the seriel number and not model number
How would I find this out will try to post picks and s number
kfa4303
Banned
Re: older evinrude
Hi fishi. Welcome to iboats. Look on the transom clamp for a small metal tag riveted in place. There should be a model and ID number. It may have been painted over at some point too. If you can't find that tag, look for a small metal disc (welch plug) on the powerhead with a serial number. You also just post a pic.
fishi
Re: older evinrude
Found one on transom clamp all it has is seriel where is the other one?
How do i post pictures
HighTrim
Re: older evinrude
Post whatever you have
There is a little icon above where you type that will say Insert Image when you hover your mouse over it. Click it
F_R
Re: older evinrude
That IS both numbers. They have the format XXXXX-YYYYYYY, where the letters or numbers before the dash are the model number, and those after the dash are the sequential serial number.
fishi
Re: older evinrude
is the model number supposed to have letters
how do i figure how old it is and what hp it is
numbers are
1502 30379
fishi
Re: older evinrude
I think i found it according to one sight it is a 15 HP 1953.
The HP sounds right but does that look like its that old.
It still runs good but there is no water stream coming out of the motor should there be one for this old of a outboard?
HighTrim
Re: older evinrude
It is a 1954
The water will exit with exhaust via outlet. Likely time for an impeller
