Older ESKA
deserteagle7008
Replaced the points and condenser, then set the points because there is no spark. Got a little shock from the wire but still not getting spark even after all the replacements. Not sure if it’s because of the “Stop,Start,Fast” handle position or what. Any thoughts?
brim_buster
You have a model number so we know what your playing with? Should start 217- from the look of the pics. Looks like wrong plug should be a J13Y gapped at .30. Ohm test your ignition coil. The small motors used the J8 like the 1-2.5hp
deserteagle7008
This is pretty much all I could find as far as numbers.
brim_buster
Thers going to be a tag on the transom bracket with model number and serial.0631e9d9e3a84223b41d3659f53059ff.jpg
brim_buster
Did some research that power head made in 1967 its a 5hp. Trying to figure out the letter C
brim_buster
Have you rotated the shaft to see if they are opening? Dumb question but had to ask. Ohm test the coil.
