Hi Guys
I have an issue with this 150 merc that started yesterday and for the life of me,I can not seem to figure it out. When it is at idle,all of a sudden it will stop running on all the cylinders except for about 3.After a bit it will pick up and run normal again and continue to do this.The problem is that it does not cut out just 1 bank,but 2 on one side and 1 on the other. Now here's the clincher.If I just raise the idle by "a hair" with the carb bar,it runs perfectly fine indefinitely until I let it go back to idle. Just a slight increase in the rpm solves the problem. I check as best I could for bad wiring,moving wires when it is skipping,but that makes no difference. I moved wires coming from the trigger,but no difference there.Both power paks and all coils replaced last year along with the carbs being rebuilt. I cannot figure out what is going on.The electronic fast idle unit is not hooked up and hasn't been for a long time.Has an idle jet been plugged in one of the carbs? Again this just started yesterday.I sure would appreciate any input. Thank You ALL Very Much
