1977 140 HP OMC Outdrive- When reducing throttle position from WOT toward idle (neutral) the engine will suddenly speed up like the transmission shifted to neutral. This happens when the engine is at about 1500 RPM. Further reduction in throttle position engages the gearing until the throttle is moved to neutral. No other shift issues noted. Did not do this last year. Checked battery voltage-at full charge.
