andyman2010
- Apr 18, 2010
- 22
Hello,
MODEL: gg9021a - Gale model 12D13
SERIAL: 55x592832 - 570954
I recently purchased a Sea King for cheap. Runs fine, but impeller may need work. Not circulating water. New to boat motor repair, not new to mechanics. I am needing some pointers.
How do I test the impeller? I read something about a drill in water. I imagine this means removing the lower end and placing in water and rotating with drill to see if pump is working? Is that correct, can you offer some advice here.
I am also in need of finding a repair/parts manual so I may methodically replace parts. Carb kit, impeller, plug wires, coil, etc. She runs ok, but I want my 10 year old to be able to start this puppy..... his boat.
I really would appreciate someone expertise here. I have read this motor is same as Johnson/Evinrude from that era and parts should not be too hard to find.
My son and I thank you!
