Old Sea Doo
brhodes
Hi all,
I've been trolling here for about a year, haven't posted much, more in learning mode than anything. I have a 1988 Sea Doo sp, last year goobered up the splines on the motor end of shaft under normal operation. I pulled pump off last week, and when comparing the shaft to the one I had replaced years ago, same issue. Now as I look at the splines on the flywheel, it doesn't look like much bite is left. I need to get this out and take a close look at it to decide if I need to replace, so I need to take off magneto cover?, and bolt something on to stop motor from spinning, then get a spline tool to put on pto end. If I have no splines to bite on, I'm wondering how hard it is going to be to remove this. Are there alternate methods to remove the flywheel, am I on the right track. I also notice when looking at back of boat, through the bearing on hull, it is slightly out of line with flywheel spline. What is the correct way to fix. Thanks for any info. Great site, bought a boat this year and man am I thankful I found this place first.
Jeff Walkowiak
Re: Old Sea Doo
to get the p t o off remove the rear spark plug use a good oil soaked rope and feed it in the plug hole be sure the piston is close to top dead center on the up stroke,, use a big huge monster lol.. pipe wrench on the pto since you are throwing it away any how,, and probably a piece of pipe on the handle for leverage and unscrew the p t o,, the rope will stop the engine from turning, when the p t o breaks loose and you pick yourself up off the ground you will be fine.
brhodes
Re: Old Sea Doo
Thanks for the reply, I learn new stuff on this site every day. The ole oil soaked rope trick, put that one in the back pocket:D. I appreciate the help, I'll post picks of the carnage that follows.
NoProps
Re: Old Sea Doo
How did all of this turn out? I just did mine and am rerunning a shaft that looks just about like that one in the picture.
Are they not made that way new from the factory? The barrel looking cut that is???
