Old Mercury Mark 25
tjhamms
Hi, I have a Mercury Mark 25 Serial# 1039435 that I'm trying to get running . I don't have any history on it. Does anyone know the proper plugs and gap for this motor. It seems there is limited info for older Mercury outboards. Thanks
Laddies
Banned
Re: Old Mercury Mark 25
J6C gapped at .025. point gap if you need it is .020
tjhamms
Laddies, Thanks I will pull the flywheel and check the point gap. Do you know how to set the timing if needed?
Laddies
Banned
To set the timing you will need a timing plug or dial indicator, if someone hasn't timkered with it it will be OK and has nothing to do with starting at all.
