Re: Old Johnson Sea Horse 3HP outboard
One thing to also take into consideration, is the contruction of the outboards too. The 10hp's and larger consisted of needle bearing crank and rod set (non-friction) ups in those years and the manufacturer specs recemended 24:1 on those models. The 7.5hp and smaller, didn't have any needle bearings at all (friction)and ran metal to metal rod to crank set ups. So, it would make sense to me why the heavier mix would have been an issue. Another thing I noticed is the 7.5's and smaller had the 4 gallon gas tanks, hence the 1 quart per tank, making it a 16:1 ratio, where as the 10hp and larger had the 6 gallon tanks, hence the 1 quart per tank, making it a 24:1 mix. Since these motors are older now and a bit worn, 24:1 should run just fine.
