I have a honda 7.5hp engine on my new little boat.<br /><br />The engine starts (eventually) but when you go to low revs it stalls. It also stalls if you rapidly put up the accelorator. <br /><br />I have repalced the spark plugs and also cleaned the carb. I am unsure of what to set the mixture screw or whether this could caucse this issue?<br /><br />I also notice there seems to be a screw to adjust air? this seems to be something you are meant to do with your fingers as it has no place to insert a screwdriver. When I got the the engine this was done up tight. I dont know if this is anything.<br /><br />when the engine is running it seems to work fine. It is only in the low revs although when i was on the water you couldnt put the accelorator to maximum as it would start to choke if that is the right word!<br /><br /><br />Unfortuantely I don't know the model but it is a pull start one
