Re: Old gas
It is running out of gas, Carlos. Things to check:
Is the vent open on the gas tank?
Are there air leaks in the fuel line connectors?
If you pump the primer bulb when it starts to die, does that keep it running?
Is the fuel pump pumping fuel? Take the line from the pump to the carburetor loose and stick it in a bottle. Turn the engine over. Does fuel squirt in the bottle?
