Old Evinrude "what is it?"
jarhead76
Ladies and Gents,<br /> I am very new to this boating thing(stream flyfisher) but I recently picked up a outboard motor, its old but for some reason the look appealed to me. Im tryin to figure out what it is (i.e hp and year). Here is what i have so far it say evinrude super fastwin on the side, the serial number is 15012-45652. Also i tried to start it and it doesnt look like im getting any spark would anyone know where to get parts for one of these? Thanks for all the help for those who reply.<br /><br />semper fi and tight lines
alcan
Re: Old Evinrude "what is it?"
Hi Jarhead<br />You have a 1953-54 15 hp evinrude. If your not getting any spark, you will need to remove the flywheel and check the ignition components, points, coils, wires,etc. These a comman service parts and should be readily available.
jarhead76
hey thank you for the info, you had mentioned that the parts are common and should be readily available...where might i find them?<br /><br />thanks again for the info
alcan
Hi Jarhead<br />Your nearest OMC dealer should fix you right up. You may be able to order from your napa dealer.
