Old Evinrude Motor
S.T. Marine
Re: Old Evinrude Motor
Hello,<br /><br /> Your motor is a Evinrude 3 hp from 1938. Thank you!
cwwalker
Captain,<br /> I also have an old Johnson serial number 347848. It is called a Johnson Twin. What is the year and HP? Thank you. Chuck Walker
JB
Howdy, CW.<br /><br />What is the Johnson's Model Number?
cwwalker
JB,<br /> The model number is KA 10. Serial number again is 347848. It is a Johnson. I did not see the model number at first, but it was there right on the top on the housing for the starter pull. This is an old one. The numbers have been hand stamped. Probably early thirties. Thank you for the help. CWWalker.
JB
Howdy, CW.<br /><br />Your Model KA-10 is a 1940 10hp. It uses a Champion R7 or modern equivalent spark plug gapped at .030. <br />24:1 fuel mix.<br /><br />Good luck. :)
