I picked up a 1971 merc 75 outboard this winter. It turned over in the guys garage, but I did not do a compression check when I bought it ($200). When I got it out on the lake I found it could be started, barely, and reved up, again barely. Today I finally hooked up a compression tester and found the top cylinder to be at 90psi, the bottom one is at 70psi. Both holes have spark. I bought this with the idea that it could be a trolling motor to push my old 70's fiberglass boat slowly around the lake .
I don't really think I want to spend a fortune fixing such an old motor up but I think the carb needs rebuilt to get it idling/running. I know the compression is poor but I don't want to pull it apart and overhaul the engine. My question for you is if you think it will run for awhile if I only rebuild the carbs, or should I just get rid of it and not poor money into a dying cause?
