dingbat
- Nov 20, 2001
- 16,883
Ive got a 1986 Merc 175 Black Max for whatever reason seems to eat poppit valves. I end up replacing parts of the poppit valve on a regular basis anymore. <br /><br />Two years ago it was a complete rebuild but last spring I replaced only the spring and the diaphragm only to have a spring fail in late fall. This spring I had good water flow out the pissr on the first outing but after that I only had a dribble at best. I had good water pressure (15-16 psi) and good water flow out the prop and exhaust ports but just couldnt get a decent flow out the pisser. I pulled the stats and cleaned them and even blew out the water hose running to the pisser but still nothing. I even removed the poppit valve and back flushed the system with a hose but nothing seemed to help. Finally in desperation I changed out diaphragm in the poppit and it nows shoots water about 4 across the drive. Everything has been good since but Im wondering why Im having all these troubles with the valve. Has anybody experienced similar problems?
