mike64
- Apr 10, 2008
- 1,042
We bought a 3-person tube for the family, the kind you sit back on. Thing is freakin' huge-- it's a floating couch. I tried inflating it with a 12v air pump and fitting it into my little 16' runabout in the driveway, but anyway I fitted it in, it looked ridiculous and completely blocked my view behind.
So I had an idea...went to Radio Shack and paid $7 for a socket for a 12v plug-in. Wired it to the boat battery. It even came with a mount I used to attach it to the boat at an unused bolt hole in the boat, so it was up high, away from any water that might get in.
So we took the deflated tube out on the water and I ran the air pump off the battery, hung the tube off the side and blew it up. It worked great! When we were done we just deflated the tube and back in the boat.
I'm just wondering if there's any potential problem with this setup. I make sure the battery has a full charge, and it seemed to handle the power drain from the pump just fine. Could I short the battery if waves get over the boat and hit the 12v socket? Any risk of shock? Anything else I'm not thinking of?
