Hello there, thank you to all of you that have helped me. This hopefully is my final post.
1978 galaxie 22xl with merc 260 chevy 350 crate motor with 110 hours on it now.
Was pulling around 4000 rpm with the 17p prop on boat with a stuck exhaust valve, and actually one of the plug wires off. Don't know how I got there with 6 out of 8 cylinders, but that is the fact. Boat backfired at wot.
Took comp test after fixing stuck valve, all cylinders within 10% of one another. Things seem good.
A friend of a friend who was an auto shop teacher for 35 plus years, helped me get everything back together, set the timing at 6 degrees btdc, check all wires, points, etc, and got it running smooth at idle, everything seems perfect.
My problem is I can go 95% throttle at around 3200 rpm with 17p prop on boat. Soon as I mash the throttle down all the way, maybe hit 3300-3400 boat backfires. Back off the throttle to around 3200 rpm, and ran perfect for an hour no problems......supposed to be around 4200-4600 at wot correct?
Now I thought lean condition causing backfiring, checked fuel pressure has 5-6 pounds of pressure, that should be good according to what everyone has told me.
I went two steps richer on secondary metering rods. Still backfiring....WTH??
My friend gave me vaccum gauge to test. This should tell me whether I have another valve problem correct? The backfire is coming out the carb which should indicate sticking intake valve, or possible lifter problem, or weak or broken spring correct?
This is my last ditch attempt to get this boat running smooth, I got this for a steal, I don't want to dump anymore hideous amounts of money in to it, or I will just sell it.
Please help!!!!
Thanks!!
Please help!!!!
Thanks!!
