- Apr 17, 2002
- 71,388
Hi All,......
I've got a 1954 Johnson, 5.5hp outboard that I bought at auction many years ago,....
It came with it's pressure tank,+ everything is/ was in Cherry condition....
Well,..... It sat in storage til a couple years ago,... I pulled it out,+ had it gone thru by a local shop here.... Installed it on the 12' rowboat for the kids to play with.....
It's ran Perfectly,....... Til last weekend when I tried to use it for pulling the Houseboat across the river to get it on it's trailer....
I've used it in this capability a couple of times since last year when I stole the Houseboat at auction....
Well,....
Last weekend, I had the Tugboat hooked up to the Houseboat,+ as soon as I had Deb release the last of the mooring lines,......
The Wind kicked up,+ the Motor Died........
After a short but Extremely Exciting ride,...... I managed to get things back to the mooring lines by continuously Pumping the Tank to keep the motor running........
After deciding to borrow a Bigger Tugboat,.... I took the 5.5hp off the rowboat,+ brought it home to Fix it.......
What I've found is a Hole in the bottom of the tank,.....
Which brings me to my Question........
Is there a Work-around to salvage this motor,..??..??......
I read the sticking thread about it, but it seems the higher hp motors in that thread are of a slightly different design,......
I guess I'm looking for a way to add a Fuel Pump to this little bitty motor,...
But,.... The pressure port is under the Carb,+ not along side the motor like is stated in the sticky thread.......
So,........
Can it be Done,.......
Or,......
Do I have to repair the Tank,..??..??.....
Thanks..........
Well,....
So,........
Or,......
Thanks..........
