D.J. Diver
- Oct 10, 2001
- 5
Hello all,how are you doing? Thanks for reading this post and for any input.I just received my 25 HP Mercury 2 stroke that I bought through the i-boats special program / lease return.After looking her over I slapped the ears on her and fired her up.She started right away and purred like a kitten.I let it idle for a few minutes and then shut it down. A few minutes after that I noticed an oily/watery, black/dark brown liquid draining from the junction of the leading edge of the prop hub and the lower unit housing. Is this just normal drainage of exhaust and cooling water mixture or could there be a problem. I checked the lower unit lube and all is well with it,which in my mind rules out a leaking prop shaft seal.Thanks for your reply. :
