I've reviewed previous posts but haven't been able to find an answer so I'll try again. <br /><br />1988 Mercury 175hp V6 with oil injection.<br /><br />Is there any way to determine if the oil warning module is bad? I do not get the 3 beeps when I turn the key. I have 12v on the purple at the buzzer. If I ground the tan/blue from overheat sensor, I get a buzz.<br /><br />Should I just replace the module or is there somethng I'm overlooking?<br /><br />Thanks
